Hi people, I have a nice little consumer unit change to do in a couple of days. Quite a nice little job if you ask me but the funny thing is, it's in a flat and there are only three circuits. Lights, ring and cooker. What are your views on the type of CU I should put in? My thoughts are to use just a normal 4 way CU with main switch and just one RCD as I don't really see the point in using an 8 way dual RCD unit for such a small amount of circuits. Another thought I had was to use a 4 way board with each circuit protected by an RCBO, but this method puts the price up a bit.
The way I see it, if you can install a 12 way with 6 circuits protected by one RCD on each side then what would be the problem, if at all, with installing a 4 way with 3 circuits protected by one RCD? I mean, technically, no board complies with BS 7671 unless each circuit has its own RCBO but is this something that comes down to what is reasonable? By this, I mean is it reasonable to install an 8 way, dual RCD unit for just 3 circuits or would using just one RCD suffice?
Any thoughts?
Any thoughts?
