N
Naz
Hi all
further to my prev thread, thanks for the advise from the members.
The old CU is a metal box size 265*135*85mm, re-wirable fuse's. The wiring is run in steel conduit and this also acts as the CPC. The conduit is bushed to the metal CU box and everything is fixed firmly against the back wall.
I have a few worries doing this job and hope that you all may be able to suggest the best way forward.
1. Any new CU will be larger than than the unit being taken out meaning I may have to to cut the conduit to size. Im not sure how I would cut conduit held firm against the wall.
2. I would loose the thread and hence the bush fitting arrangement and thus my earth continuity.
I would like to put in a small CU ie 8 way and give the customer the benefit of rcd protection but with out circuit cpc's this will not be the case.
The customer also wants a cooker cable run to the Kitchen, running the 6mm cable will not be a problem and would ideally be run to a new CU with 32m mcb.
I will attempt to attach a pic to clarify
I have not suggested rewiring yet since I had not considered this originally and it would mean an extra cost implication. Also from some threads it is suggested rewiring steel conduit systems can be a nightmare.
regards
Naz
regards
Naz
