CU change in ex council flat | Page 2 | on ElectriciansForums
Discuss CU change in ex council flat in the Australia area at ElectriciansForums.net
N
Naz
Hi all
further to my prev thread, thanks for the advise from the members.
The old CU is a metal box size 265*135*85mm, re-wirable fuse's. The wiring is run in steel conduit and this also acts as the CPC. The conduit is bushed to the metal CU box and everything is fixed firmly against the back wall.
I have a few worries doing this job and hope that you all may be able to suggest the best way forward.
1. Any new CU will be larger than than the unit being taken out meaning I may have to to cut the conduit to size. Im not sure how I would cut conduit held firm against the wall.
2. I would loose the thread and hence the bush fitting arrangement and thus my earth continuity.
I would like to put in a small CU ie 8 way and give the customer the benefit of rcd protection but with out circuit cpc's this will not be the case.
The customer also wants a cooker cable run to the Kitchen, running the 6mm cable will not be a problem and would ideally be run to a new CU with 32m mcb.
I will attempt to attach a pic to clarify
I have not suggested rewiring yet since I had not considered this originally and it would mean an extra cost implication. Also from some threads it is suggested rewiring steel conduit systems can be a nightmare.
regards
Naz
That would be the course i would take with this installation too. But i would remove the the hinged door and replace with a lid made of galvanised sheet steel. Can't have a gaping hole where access to the main switch once was!! As Tony stated i would also add banjo's or piranha nuts to the conduits entering the old CU. Also i'd be getting rid of those earth clamps to the conduit, and especially that SWA cable, and create a pukka MET.
I don't like these split RCD CU's, although more expensive, i would always favour RCBOs. Thus making the CU far more secure and adaptable in the future, and without these multi circuit RCD problems, that seem to be the subject of threads here, on a daily occurance on the forums these day's.
Yes mate spot on you need to remove the existing board face plate and knock up another one but done it many times and it can look quite good, especially if you have a mate who owns a metal workshop with a press and guillotine lol
I have actually seen conduit couplers where you can cut the conduit in place and knock them on the end of the existing conduit, i dont know if they do them in imperial sizes though, also dont know how good the earth continuity would be through them but maybe its worth a look???
then you could loose that old cu alltogether
Welchyboy, i've seen a couple of these as submitted samples on my projects, i don't believe they can be relied on for long term continuity, they are not particually too clever even when new. Systems using such push-fits would in my opinion require a separate CPC to ensure ongoing long term earth continuity....
Have you just wandered in off the plumber’s forum? Those things are awful!
Reply to CU change in ex council flat in the Australia area at ElectriciansForums.net
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
