CU change. What would you do about these tails?
B
brman
I've got a CU change in a couple of weeks. I did a pre survey and everything looked ok except I have just realised I take much notice of the tails. :sad_smile:
The trouble is the CU is in what was the garage however the garage has been turned into a room by plasterboarding the walls - hiding completely where the tails go. Meter is external at the usual waist high, CU is about 30cm from the ceiling inside, about 2m horizontally from the meter.
So....
a) I have no idea where the tails are behind the plasterboard. As it was originally a garage they were likely to be surface mounted I guess but it is quite likely this doesn't align with the correct zones in the present room and the almost certainly aren't 50mm deep.
b) I can't be sure but I suspect they might be a slightly over 3m long.
So I guess the question is, what would you do?
I am thinking I really should be trying to trace where they go and do something about it if they aren't to the regs. On the other hand I am changing the CU, not the tails and I don't know that they are wrong. For all I know they are mechanically protected where I can't see them and ripping out tails that have worked fine for 20 years and potentially fitting a switched fuse because of the length feels a bit of an over-reaction.
what do you reckon?
Correct me if im wrong, but, dont the new EICR also include meter tails and earthing as part of the remit??
IF thats the case then it should be noted as stated, and a phone call to the DNO?
I am not sure I follow. Why inform the DNO? I didn't they cared about anything from the meter onwards?
brman,
brman,
