CU Change | Page 2 | on ElectriciansForums
Discuss CU Change in the UK Electrical Forum area at ElectriciansForums.net
L
LankyWill
Just a quick one.. I only really install brand new CU's and Dis Boards in my current firm. I have been asked to do a CU change for a friend. In terms of testing what do you guys actually test? when only changing the CU itself? Should i just test the rcd trip times and Ze, PFC. I mean if i think about it, its only an accessory and i havent changed the overall design. I could liken it to changing a light sw, just takes longer.
Whats the protocol on this?
Like like like like like (I think)
CU changes the control of everything, so I start from inspecting and testing everything. Special mention today is my fav rfc. I will check rings for continuity, ratio, value and estimated run. Only takes a minute when you've got it all apart. If not as expected I won't commission without discussion, investigation and fix. You are doing CU and it's probably the first thing done there for ages so there can easily be a problem with a kitchen outlet due to high use etc. Easy to fix, but you need to know there is a problem to fix :) . You don't want to stick 32a mcb on what's now a 2.5 radial probably buried in the ceiling under one of the subsidised insulation upgrades ... Hmm toasty. Cheers, David.
I just got home from the quickest CU change I've done in a while. Only two circuits (lights and sockets). Both tested absolutely fine, despite dating from the late 70's. I expected at least some remedials prior to the changeover, the best I managed to muster was replacing a pendant.
iv'e not been on this forum for a while. It gets dafter by the day, I think my Jack Russel has more electrical knowledge than some of the dreamers on here, 100L kettles on a plug top, RA's for obvious breaches of the regs by idiots (managers), what the hell is going on?????
Christ lads only having a wind up!!! This is the sort of mistake i have to put right daily and it winds me up. Went back to a customers house today to carry out an EIC from an CU change one of our lads did a Month ago. I looked like a right tool!! at least its safe now anyway.
Dave likes this post. Didn't take long for the terriers to start nipping at your ankles eh Will. :juggle2:
I don't like not having a like button, I liked it better when we did have a like button, but now it's gone I don't like it at all, and on and on
Reply to CU Change in the UK Electrical Forum area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
