A
AliRaZoR
funniest forum's members
Hi
Could any one teach me, how to design and install a CU?
How to select RCD,MCB(and connection)?
thanks in advance.​
college course can. then loads of experience after that. before designing CU, you have to design the circuits that it's supplying, decide how you are going to organise the layout in the CU, then the type and rating of overload devices RCD or RCBOs, etc., etc.
That's kinda like requesting that someone on a forum board teach you how to drive a car. Installation work is a bit more involved than you may think it is, every installation is different so there's not just one foolproof way to do all installations.
Assuming little or no experience, then this is not the sort of thing you can learn from a book. You could learn from several books, but you will need some experience, and probably someone with the relevant experience. I don't wish to offend, but design, construction, installation, and testing and inspection is a bit beyond someone who wants to learn from a book. It is not rocket science, but there is a lot to it, far more than could ever be covered in this forum at one go.
As Tel rightly says again, its a college course at the very least to get to the standard.
Cheers..........Howard
Ask in B@Q is my best advice they sell them so they must no how to install them or read the instructions!
Or pay anything upto 5k and do a 4 week course :D
You need to know where in the book to find the specific information you need.
There's a 10 week course on that. Yes, a 10 week course on how to read a book!
thanks for reply, i am going to start reading of that book, but my main interest is the way that you connect MCB,RCD,... in CU.
Well that's the easy part. Before you even take the old one out you need to test the installation to check for problems such as borrowed neutrals which will cause problems later.
CU Installation, Step by Step
Australia
AliRaZoR,
Spudnik,
