CU Locations | Page 2 | on ElectriciansForums
Discuss CU Locations in the UK Electrical Forum area at ElectriciansForums.net
C
chloebear
I have been requested by the developer on a site building a number of small houses to site the consumer unit in the downstairs toilet. Cant see too much of an issue with this, however he wants it above where the hand basin will be and not at the WC end.
I have had a look through the regs book and also building control info and am unable to find any reference to the siting of consumer units in this regard, maybe i'm missing something. I can find reference to socket outlets etc not being too close to water and locations containing a bath or shower, but nothing relating to consumer units near hand basins??????
am I missing something in our wonderful world of over protective regulation?????
I would position it there for future proof purposes. I heard on the grapevine the 18th was going to force new CUs to be sited within 0.5m of a water outlet. Something to do with having access to water to put out the fires in 'non-combustible CUs'. There's also weak rumours that the 19th will mean installing new CUs in a bath-tub so that there's no risk of any fire starting at all, which means plastic CUs will be allowed to be used once again.
Ask yourself
if you could comfortably work on the CCU for any extended period. Accessibility includes maintenance access.
Yes, customers hope to locate CCU as unobtrusively as possible, that does not mean we should not try and get them right for working on them and regular RCD testing by customer.
Ask yourself
What's that when it's washed 'n' dresssed?? :whatchutalkingabout
An accessible main switch in the external meter box (preferably provided by the DNO) becoming mandatory would be a very good idea in my opinion
Not such a good idea when you come back home from yer hollys and find the food in yer freezer has gone off cos some little scallywag turned yer leccy off at the switch in the ootside cabinet.
Reply to CU Locations in the UK Electrical Forum area at ElectriciansForums.net
M
Bathroom first/second fix plumbing costs Hi all, I just got a quote for bathroom and WC plumbing LABOUR only first and second fix ÂŁ3850 for the...
midaslegend
M
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
