CU Replacement - Upstairs and Downstairs Rings Connected | on ElectriciansForums
Discuss CU Replacement - Upstairs and Downstairs Rings Connected in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SW1970
Hi, newbie here. Done a domestic PIR and Consumer Unit replacement is required (damaged, lighting circuit not earthed or RCDd, plus other reasons). However, another finding was that the upstairs and downstairs ring final circuits are connected (currently installed as the 2 live cables going into the circuit breaker).
Cable size is 2.5mm2.
Total floor area served is 85m2.
Circuit breaker is 32A (RCD protected).
After finding out rings were connected I did cross connected line conductor resistance test at each socket and it looks like the rings are connected at the extremity and not bridged half way round. I've deduced this as the resistance readings are almost identical to within 0.01ohm.
Customer doesn't want to fund sorting out the rings (tricky as laminate flooring and fitted furniture everywhere).
I'd appreciate views on whether it OK to proceed with CU replacement and re-energise with the rings remaining connected as they are now? Clearly it doesn't meet the suitable segregation of circuits requirement, but this appears to be the only failing. Any thoughts?
Many thanks
SW
Hi, CU replacement is required anyway because the existing one is damaged, but circuits are:
Cooker
Downstairs lights
Upstairs lights
Garage lights
Garage sockets
Upstairs and downstairs sockets
Utility room sockets
Cheers
SW
Topquark - could be. House is 1963 build. Utility room is an extension so that would explain why it's on a separate circuit.
As your readings are all pretty much identical my first guess would be only one ring. How many cores do you have back at the CU?
SW
Same question as topquark,
I dont quite get what that description is suggesting
Two 2.5mm2 cores going into the MCB labelled sockets upstairs and downstairs. So if it is a single ring installation, ok to proceed with CU replacement and identify the segregation deviation from BS7671? Cheers, SW
If you have 2 other socket circuits, then I wouldn't even be concerned, I don't see a safety issue on a nuisance trip?
The
'departures' box is strictly relating to your work only and if you did feel the need to make a note, it should be recorded in the 'comments on the existing installation' box.
Well you have segregation to a certain level because of the seperate utility sockets
An household ring and a kitchen or utility ring where most of the heavy loads are sited would satisy the segregation of circuits requirement in my opinion
Sorry to sound pedantic but this is 'division' of circuits rather than segregation.
Point noted :D
quote Sw
It is sometimes just as well talking the same language :)
Reply to CU Replacement - Upstairs and Downstairs Rings Connected in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
