CU replacement - what is the recommended certification duration? | on ElectriciansForums
Discuss CU replacement - what is the recommended certification duration? in the UK Electrical Forum area at ElectriciansForums.net
I
imprints
Following a replacement of the consumer unit – what is the recommended certification duration?
In GN3, there is a table of recommended maximum intervals, this is table 3.2 p65 in the new GN3.
Private domestic the maximum is 10 years.
Rented domestic the maximum is 5 years and/or change of tenant.
The recommended interval can be earlier, for example if the wiring is old and tatty and in poor condition and say your IR tests are on the low side but still pass, you as the inspector will have to make this decision based on your experience, as only you will know the condition of the installation during your I&T.
As said above, the maximum is 5 years for rentals, but it can be earlier, If the council want it every 3 years then he who pays the piper calls the tune.
Maybe they know something you don't lol:rolleyes2:
Reply to CU replacement - what is the recommended certification duration? in the UK Electrical Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
