Discuss CU Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
are you really registered with a competent persons schemeWhen changing a CU what cert should be given and what tests need to be done??
my mistake, thought you had your assessment on 4th januaryNot as of yet, but as long as i issue a cert and notify building control i am ok, this is what i believe anyway??
if you test first you shouldnt have any problemsAlso if i come across problems can the job still be done aslong as i notify this on the cert and tell the customer??
quite right about notifying before work starts but i wouldnt think they would check a cu change beforehand as its all exposedYou are right but you have to notify building control before you start the work so they can come out and see it during the work and then after and they will do an Inspection & test. This will also cost you but not sure how much. Where I live its about ÂŁ110 for jobs under ÂŁ2000. But in a near by city its about ÂŁ500, so it depends how much your lbc will charge.
oops forgot to mention tails, cant believe someone who has already changed cu`s is asking these questionsAgree Check bonding and tails etc also before a cu change i always do continuity and ir tests ! you may open up a can of worms and if you do your prepared for it !
Reply to CU Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
