CU Updated But No Rewire | on ElectriciansForums
Discuss CU Updated But No Rewire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Luton, Bedfordshire
Hi Guys,
Wanted to know your opinions on a situation I came across recently. Long story short customer wanted their old CU replaced to a modern updated one (RCD protected) but did not want a full rewire. The original CU was a Wylex 12 way rewireable fuse unit, instead of the usual ring main setup this was a radial circuit in 4 mm feeding each room with several sockets. Included were the usual cooker, shower circuits etc. Tested out the installation and it passed but some (IR) readings were on the low side. Did mention this to the customer but his response was that he simply does not have the money and the time to do a rewire of the house at this present time.
What would have been your response if you were in the above situation?
Many thanks.
Sayeed
Personally I would have done a global IR prior to any works then I would have highlighted any anomalies. What where the IR readings?
At those readings the installation is good for years to come.
I've had readings of 10-12 Megohms on various circuits and across all conductors when upgrading CUs , nothing to worry about as it's still a very high resistance !
@wirepuller
You've not missed anything, rather my misunderstanding, I'm so used to seeing >200Mohms on the tester, seeing around the 50Mohms mark just got me wondering if the installation was still of good quality.
Thanks guys for the input.
It's not as good as new, but there's a good reason for that... it's not new!
It's way in excess of the requirements, so bobs yer uncle...
What type of cable is it?
Have you actually calculated the leakage current you will get from the IR results? Or do people not bother with things like that any more?
Reply to CU Updated But No Rewire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
