CU upgrade.... bit of a squeeze... help please.
sythai
Hello chaps,
Got a CU upgrade coming up and not much room, it's only 4 way though.
I've 260mm spare on the width, otherwise will have to move a night store cu which is fully loaded or splash out and buy a small cu with main switch and load with RCBO's.
So need the smallest dual split load really, any thoughts please ?
I did use a wylex NHRS23204 before when in similar situation, but cant seem to find the dimensions anywhere online ?
Thanku,
Sy
