CU with no main switch - is it acceptable? | Page 2 | on ElectriciansForums
Discuss CU with no main switch - is it acceptable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think it was the last spark who fitted the shower but im sure I can find out! :yes::yes::yes:
better to wait than be fined 16k for breach of H&S regulations
First I've herd it being a breach of 'H&S regulations', I was always under the impression it was tampering with DNO property....which nobody has ever been charged with to my knowledge. EAWR are more in favour of you encouraging the main fuse to fall out anyway
reference to first post, doesn't having an RCD fitted in the CU count as the main switch for the Installation,the CU doesn't have to have a 100Amp switch and RCD, RCD is acceptable on its own.
I agree that an Isolator of sorts should be fitted so the main DNO fuse doesn't 'fall out'.
another question leading from this, say the DNO fuse has fallen out, Can an Isolator switch be fitted and where can they be supplied from, or DO the DNO HAve to fit them.
Edit - Just reread first post and noticed 2 RCD's fitted, so unless 2nd RCD fed from 1st RCD (not good practice), then wouldn't be safe.
Reply to CU with no main switch - is it acceptable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
I replaced a CU a few months ago along with isolator. Along comes Mr Eon meter man to fit a smart meter told the customer that he has to replace...
