Cupboard lighting push switch | on ElectriciansForums
Discuss Cupboard lighting push switch in the UK Electrical Forum area at ElectriciansForums.net
Steviecuk
Essex
Hi all. I've just bought a cupboard push switch to turn the cupboard lights on when I open the door.
It's just a single in-line switch in a plastic housing.
The switch will be switching 240v mains taken from the lighting circuit but what are you thoughts... should I wire and switch the live or the neutral wire to break/connect the circuit?
Cheers. Steve.
Cheers. Steve.
Always switch the Live, otherwise you would leave a Live at the light fitting when the switch is turned off.
How are you planning to connect this switch as they very often have exposed terminals?
I saw those ones but opted for a larger concealed one.
  • [ElectriciansForums.net] Cupboard lighting push switch
Reply to Cupboard lighting push switch in the UK Electrical Forum area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
Interesting document thanks. But it neglects the half-wave rectification, and also totally neglects the effect of the coil inductance when...
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
