Curious box enclosing meter, with electronics | Page 3 | on ElectriciansForums
Discuss Curious box enclosing meter, with electronics in the UK Electrical Forum area at ElectriciansForums.net
SJD
Mentor
Braccan heal
Can anyone cast some light on a curious meter I came across today.
The old-style meter has a circuit board fitted on top, and the whole lot enclosed with a Perspex cover, with meter seals at each corner to prevent access. See photo below (hopefully).
[ElectriciansForums.net] Curious box enclosing meter, with electronics
What is this for?
I'll try to add a close-up of part of the board in another post.
A tamper (a.k.a rammer) is a lump of iron on the end of a long handle used for compacting soil or asphalt, e.g. where a power rammer can't access.
Looks very dodgy. The plastic cases were fitted in cases where the meter had been tampered with, a new meter would be fitted and the plastic cover fitted. Although it wouldn't prevent another go at interference, it would be very obvious, so no chance of 'I don't know anything about it!'. I don't think a meter would be left with no terminal cover fitted though, so could be a 'black box' has been fitted, to slow or stop the meter. I woyld certainly advise you to contact dno or supplier.
a lot of houses were built with these perspex enclosures i outside meter boxes. think the idea was to prevent tampering before the fact rather than after.
They were definitely after the fact! Tampered with meter was removed as evidence of theft, and a new meter fitted. Originally we used fixing scrrwd that could only be tightened, not undone . All sealed up and supply left on. Sometimes had to drill hole for cards if a card Meyer fitted
Looks like an early generation IC/SS power line communication set up. A predecessor to the ethernet over power plug-in systems you get today. Probably used to remote read the meter.
There's green LED on lhs, does that flash at any particular rate linked to the meter rate?
I've finished work at the property, and not expecting to return, so no idea about the flashing rate.
In reply to Percyprod post #34, I was also surprised to see no cover over the meter terminals, but I guess that was to be able to connect the fly leads to the electronics board. From the board manufacturer name, I don't think it is some device to slow or stop the meter. But then again, if you were making such a device, you'd try to make it look like something else that was legit.
As I mentioned earlier it is a special meter with a pulse output to drive the telemetry module. The box is not something someone has randomly slapped over a regular meter as they don't have a pulse output.
Reply to Curious box enclosing meter, with electronics in the UK Electrical Forum area at ElectriciansForums.net
