current carrying capacity | on ElectriciansForums
Discuss current carrying capacity in the UK Electrical Forum area at ElectriciansForums.net
G
goldie
Any reason why 6x1.5 mm singles within 20mm plastic cinduit on surface shouldnt be used for a 3kw load. Length if run is about 6 metres. Fused a 13a via sf spur.
[ElectriciansForums.net] current carrying capacity
Aaah, the old, "Gotta use what I happen to have on the van, can't be bothered to get the right parts" mentality. Was it you who used a light switch in place of a switched FCU on the boiler I saw the other day???
Reply to current carrying capacity in the UK Electrical Forum area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
