Customer bought funky light... | Page 2 | on ElectriciansForums
Discuss Customer bought funky light... in the UK Electrical Forum area at ElectriciansForums.net
Leader
Bucks
...but it came with a plug and wants it to be hard wired into the lighting circuit. I haven't come across this before and I'm not sure that it's permissible? Any thoughts?
Cheers
Great looking flex though, it'll look like I've hung it on a bit of FP200.
That's not as good as my Pyro pendant.
I'd just wire the wall light in to a suitable outlet plate and stick the thing on the wall. Job done.
You could use LED lamps which will draw substantially less than 28 10W halogens. 10A is usually overkill for most domestic lighting circuits, especially now with LEDs everywhere. I switched on all the lights here, including table lamps, the loft light and outside lights and measured a current of about 0.7A total.
They both have 3amp plugs on them, tried to open them up to look at the transformer but that's a no go.
It could be a rave, the lounge lights have started strobing. I think the problem Isla with the new dimmer switch they've just put on. It's a click which I normally tend to steer clear of, anyone else have problems with this brand?
Chr1st. ÂŁ160-00 and it doesn't even include the required 28 x (max.) 10W G4 halogen bulbs ...
Just pandering to the uneducated proletariat, it looks good, it costs a lot, I can afford it, I want it, I have no sense and I'll get a man int o fit it, you or me maybe?
I did this at a customers empty house - 4 x 35w halogens on a bar in each room upstairs and down and the 2 circuits up and down drew 5.56amps both on 6 amp mcbs so with a splattering of LED would not get near the In. I love my new clamp meter!
Yep, plus another 7 for the other light. The worst part was trying to hide the cables in the wall, the back of the light was solid with no void to run the supply out. Nightmare, should've just said it wasn't possible!
Just had this job in. "Please fit this antique lamp that we've just bought, the shop owner says that it's been rewired to the latest standard" - I wonder whose standard. Great looking flex though, it'll look like I've hung it on a bit of FP200.
Red is a bit old hat now. If you want different colour flexes have a look at buy fabric cables-braided flex-lamp holders-switches-light fittings from our on-line shop - Vintage Lights Ltd - https://www.vintagelights.co.uk over 100 types
Shameless plug! there are also some instruction videos the link can be found on the home page
Reply to Customer bought funky light... in the UK Electrical Forum area at ElectriciansForums.net
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
