Customer has his own pre 17th cu he wants to use | on ElectriciansForums
Discuss Customer has his own pre 17th cu he wants to use in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
martinxxxxxx
He has already put it on a board next to the existing cu (bless him)
It is a Wylex NHRS5504ymCb Split board 6 RCD protected ways and 6 non protected ways
I think I can use this by having
On the non RCD side
Shed Sub main (has own rcd, will check Zs at this installation)
Cooker has 45A main switch
Lights down
On RCD
Lights up
Ring main down
Ring main util
Ring main up
Shower.
Will obviously do a PIR first.
Any problems?
Thanks Martin
PS normally I would just tell him to buy a new cu, but he is a bit fixated on keeping it and I am busy and job need to be done by week monday
This is not meant to be sarcastic but the medium of text communications always makes this ind of response seem so.
They are expensive and I don't believe I need them for the circuits that I have mentioned as the installation of the cooker is surface clipped direct, the shed is armored cable not buried and the downstair light are all inside permitted zones.
Do you think I should get RCBO any way, two of them would cost as much as a 17th board!
Grateful
Martin
It is a wired fixed equipment so as long a it Zs checks out and the wiring to it is either surface mount or 5cm in the wall or mech protected I don't think it does.?
In fact I have checked this with ElecSA and they are of the same opinion
Unless you know diff, I know the smashy guys have other rules.
Martin
Grateful
Martin
er , I think I did
Sorry
Martin
Reply to Customer has his own pre 17th cu he wants to use in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
