customer stupidity | Page 2 | on ElectriciansForums
Discuss customer stupidity in the UK Electrical Forum area at ElectriciansForums.net
G
gavin.sibley
Didn't think I would be turning a job down all too often, but this just takes the biscuit! I know they say A jobs a job but I like to have a certain standard to my name!
Got asked too install spotlights in a new kitchen, when I said ok floor above will have too be lifted to allow routing of cables, homeowner genuinely wanted me too just pin the cables too the ceiling! I bet that would look gorgeous ;)
Doing downlighters from above, ha, never happens unless new build.... get fishing rods out and wear a hat.
Yes, if they are going to skim the ceiling anyway then go from below.
But if not then the hole left from removing a pendant is easily filled, whereas the chunk taken out to wire the downlights takes a bit more work.
Reply to customer stupidity in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
