Cutters for 70mm tri rated Cable | Page 2 | on ElectriciansForums
Discuss Cutters for 70mm tri rated Cable in the Electrical Tools and Products area at ElectriciansForums.net
I think cutting 70mm2 cable would be a struggle with them Shanks, especially lots of cuts.
tri-rated.
ill be honest you are right i was cutting some 25mm tails with them and i wouldnt like to try bigger.
apparently there rated toto 50 stranded and 70tri but i wouldnt try it on any bigger.
my 165mm pair of knipex seemed sharper (the bolt ruins the pair so they dont cut very well, the but came off somewhere)
Will that leave a clean end on tri-rated though? I've never used a saw on fine stranded, only cable shears, which take all of a second to go through 70mm so I'd be tempted to keep the bandsaw for armoured etc. I do keep separate shears for MICC and rough stuff, so that the ones used for the more delicate cables are as sharp as poss. When they start getting chipped or slack, they get demoted to the rough work and new ones take over the delicate.
Yes, a perfect cut.
Reply to Cutters for 70mm tri rated Cable in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
Plasplugs wet tile cutter - it sucked! I recently borrowed a plasplugs wet tile cutter from a friend to cut some floor tiles. In his opinion this...
STEVEROG
