Cutting back boxes in plasterboard | Page 3 | on ElectriciansForums
Discuss Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
pc1966
V.Nearly Esteemed
Dundee
I find myself in the position of having to fit a few back boxes in to plasterboard. In the past for the odd one I just used a hand plasterboard saw to cut out a hole, but I wondered if anyone here has used something like the square/rectangular cutter adaptors you get for multi-tools to do this sort of thing. If so, how well did it work?
Suggestions for make/model?
TL;DR tips for cutting boxes in plasterboard
The Appleby ones with yellow lug pieces aren’t too bad. Only ones for me..when needed.
Generally prefer them over other makes, but lugs only allow for fitment in single board. No chance they'll fit double boarded walls without cutting away at rear board, so on those occasions I prefer 'lesser' brands.
Multi tool every time for me, but does not work on a solid flint wall with internal sand and cement render 🥴 then its a carbide tip hole saw followed with a hammer and chisel. 😱
Never heard of anyone trying to cut stone walls with a multi tool. I guess there's a first time for everything.
It works.
Ok… only a certain blade on a certain type of block… but if you’re lucky in that respect…
You can basically scrape the hole flat with a bolster chisel. No hammer involved… and make rawlplug holes with a plumbers old screwdriver.
It works.
What sort of stone are you going to spend time scraping with a bolster and why would you want to cut it with a multi tool, rather than stitch drill, chisel and scutch chisel?
It's possible to make fire by rubbing sticks together, but most people prefer to strike a match.
Reply to Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
I think I know exactly the stuff you mean - called insulating board (I think) and it's like the stuff you get on pin boards for thumb tacks. I...
