Cutting marble mosaics Discussion Thread | on ElectriciansForums
Discuss Cutting marble mosaics Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
I’ve got a job using marble geometric mosaics about 10 mm thick. I’ve tried several blades to cut these but every one seems to chip and break the corners off the tiles . wet sawing seems to be better but still the same problem.and almost impossible to see the lines. I’ve bought a Montalit dry /wet cutting disk, but still the same problem.does anyone have any advice out there ?
I’m going to buy some plastic strengthening Self adhesive backers tomorrow for the tiles, but is there anything else I should be doing that can help? Any advice appreciated before I wreck 2.5k’s worth of tiles!!
Cutting marble mosaics for the Original Article on Tiling Advice Forum
Reply to Cutting marble mosaics Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
Too thick to cut? Not a full time tiler and questioning everything but..I need a wet saw to cut a lot of 45's in 12" marble tile. Is the Sealey...
Too thick to cut? Not a full time tiler and questioning everything but..I need a wet saw to cut a lot of 45's in 20mm, 12" marble tile. Is the...
