Guest viewing is limited
Cutting marble mosaics
I’ve got a job using marble geometric mosaics about 10 mm thick. I’ve tried several blades to cut these but every one seems to chip and break the corners off the tiles . wet sawing seems to be better but still the same problem.and almost impossible to see the lines. I’ve bought a Montalit dry /wet cutting disk, but still the same problem.does anyone have any advice out there ?
I’m going to buy some plastic strengthening Self adhesive backers tomorrow for the tiles, but is there anything else I should be doing that can help? Any advice appreciated before I wreck 2.5k’s worth of tiles!!
Cutting marble mosaics for the Original Article on Tiling Advice Forum
Dan
Staff member
Admin
Mod
Staffordshire
Website
https://www.electriciansforums.net
Other
If other, please explain
Not an electrician at all.
Business Name
Ekthetikos
Cutting marble mosaics Discussion Thread
Tilers Forums - UK Tiling Forum.
Thread Tags
Dan,
