Is it a back boiler heating the cylinder?
If so, how do you disperse the heat when the pump is not running? (stop it boiling)
Boydy
On a wood burning system usually either one of the radiators or the feed to the hot water system is installed with no shut off valves. This is usually designed so water will circulate by syphon so even with the pump off, it will not overheat. In addition a pipe stat is often fitted on the outlet to the back boiler to override any controls to ensure the pump runs if it gets too hot.
