ses
Hello
I have a customer that has a CYP 1H2HBTE system
With a sky plus hd box
The system has two tv sets in different rooms
I was asked to check the cat5e rj45 connections between the transmitter and receiver for the lounge and the connector seemed a bit loose so i said i would put new rj45 plugs on the ends
However once done this stopped working completely
I spent 5 hours with 3 types of RJ45 cat5e plugs and 3 sets of crimping tools trying to get this to work again but to no avail
Ive used my cat 5 tester to check my connections and all ok
I purchased a pre made cat 6 patch cable and it all works again
The cat 5 rj45 plugs seem loose when connected to the equipment
The cat 6 patch lead is nice and tight when fitted so i can only think my connectors are too small or not making contact properly
Can someone help me im a bit out of my depth now
Can cat6 rj45 connectors be slightly bigger externally?
Is there a special rj45 for this equipment
Help
Help
