D Type MCB's | on ElectriciansForums
Discuss D Type MCB's in the Australia area at ElectriciansForums.net
Spock
Can someone confirm please - I don't think this will make any difference but - would the replacement of a B Type breaker for a D Type have any effect on whether a compressor/motor start-up dimmed the lights in an installation? (assuming that both MCB's were able to cope with the current demands)
But your Zs certainly would....
agree with glennspark. changing from a b type to a d type, will mean that the MCB will require 20x In to disconnect instaneously. This means that your Zs values need to be a lot lower in order to alow for this.
Zs= Ipf/Uo
He's back, and his fingers are quicker than ever ;)
after seeing some of the electrics in turkey, the bad things we see posted on this forum are minor imperfections.
What's Zs (or maximum allowed) got to do with dimming lights on start up?
nothing at all, was just an observation that the max. Zs would decrease id a type d were to be fitted. and be4 you say it, neither did my post about turkey have anything to do with it, except that the lights thewre are always dim. a bit like me after as skinfull
Reply to D Type MCB's in the Australia area at ElectriciansForums.net
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
