Daisy chain lights to a switch | on ElectriciansForums
Discuss Daisy chain lights to a switch in the Lighting Forum area at ElectriciansForums.net
Martiv
Uk
[ElectriciansForums.net] Daisy chain lights to a switch
I want to add 2 lights in my garage 1 near door and 1 at far end near plugs
Am i good? Daisy chaining them from a plug and a switch on the end daisy so i can turn it both on at my door?
Sick of falling over stuff to turn the lights on at far end lol..
Ive got 2 light fittings and some 1mm cable also a switch.
This will be on my extension lead
ideally you would configer the lights as 2 way switching so they can be turned on/off at either end. an electrician would be my advice for this. might also be worth considering a PIR to activate the lights as you walk in.
Reply to Daisy chain lights to a switch in the Lighting Forum area at ElectriciansForums.net
Of course, showing my age now!
Some pir lights have a switched output so you can link them together, when any pir is activated then all lights will come on. if you don’t connect...
