Hi,
Can any one advise me about the actual damage caused to a frequency drive if flashed with 500 vdc from an insulation tester?
I have an ABB ACS800 0100 drive (100kw) that has been flashed by someone. The drive uses IGBT modules fired from a control card, will it be the IGBT modules that have been damaged? These control a 400 volt 4 pole induction motorist speeds up to 3000 rpm (100hz).
I am confused to what actual damage this would cause. ....
