Dash Lights Out... Add Rheostat for dimming | on ElectriciansForums
Discuss Dash Lights Out... Add Rheostat for dimming in the Auto Electrician Forum area at ElectriciansForums.net
freehold NJ
I have a 2005 Honda Odyssey that has dash lights that are a combination of LED and incandescent. Most of the incandescent lights do not work. That results in my radio backlight and most of the buttons being off. I have tried to track down this issue and haven't found it. The factory dimmer is built into the cluster and uses a transistor to change the ground and dim the lighting. I have plans to try and swap the cluster with another, but was also considering changing the wiring to include a rheostat. I came to this forum for some guidance to see if that was possible. The van is older and is going to be retrofit for a mini camper. I don't mind drilling holes, splicing wires and adding dials to get this basic function working.
Thanks in advance for the help.
Reply to Dash Lights Out... Add Rheostat for dimming in the Auto Electrician Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
