dasy chaining boards ? | Page 6 | on ElectriciansForums
Discuss dasy chaining boards ? in the UK Electrical Forum area at ElectriciansForums.net
F
falcon0310
a big hotel group has asked us that they want 2 way dbs in each bedroom feeding one socket and 5 lights all led fittings, but they want the supplies to boards daisy chained from 10mm t&e or swa feeding 4 rooms per circuit. the only way ive ever done this is sub per board, but cant find anything in the regs, as so many jobs this is to save money but surely its not right
Wind up got to be
pete 999, so I cant make this up, this year I've had so many bad punters did I nursing home in feb eicr in feb and after hour said to owner there's no point, he said be fine carry on so we did, no rings cons, all spider joints on 30a mcbs, when I told owner no rings he said we only rewired this in 1967!!!!!!!!!! I get hold guy that did it It for us !!!!!! I said how you going do that ? he said he's in my other home and he's 75, 2 hours later he rang me back and said he wired it in ring I must be wrong the guy was English owner
no you could not make this year up for me been off work since march another subject, I keep getting blokes ringing us up that are experts, one guy in jan, wanted 72way harger board, never use ! first one damaged, 2nd earth bars hanging off not spot welded, main switch no bolts, 200a switch fuse no spot welds on glad base, poor old yeees electrical running around for 3 days try sort out, then guys doing the fit out used 6mm rod for 450 tray no uni strut then wired each bit gym equipment to there own circuit !
Right, and what does that mean?
Reply to dasy chaining boards ? in the UK Electrical Forum area at ElectriciansForums.net
