steptoe
Hi all
I hope some one can advise on this situation
We were working in a commercial premises running data ,co ax ,HDMI and a RS 232 cables for a media system (TV monitor wireless access points and speakers) The termination cabinet for these cables was on the other side of a breeze block wall.The only gap to push these cable through the breeze block wall was next to some power trunking(box metal 4 inches) which was also running through the breeze block.The cables ran 4 inches alongside(not inside) the metal trunking through the wall with a 15-20mm gap between the trunking and the cables.The cables paired off away from the trunking upon entry and exit of the breeze block
Will this cause interference to any of the cables and is it a cause for concern
The HDMI/DVI and RS232 cable are both terminated with quite large connector block ends and we didn't have a a core cutter to drill through the breeze block hence using the gap next to the trunking, it has subsequently been flagged up
I have a photo but not directly at hand today that I will post if asked
