Data cable tracer? | on ElectriciansForums
Discuss Data cable tracer? in the UK Electrical Forum area at ElectriciansForums.net
bartkusal
London
Hello everyone.
I need to get some sort of data cable tracer. Got one site where there is a hell of a lot network ports lost the labeling, need to sort this out.
Obviously the cables are mix of cat 5 and 6. As far as I understand, as long as its in twisted pairs, the tracer in my link bellow should do it? Otherwise what is other tracer would you suggest, obviously not braking the bank.
Thanks in advance for your help.
Al
Tempo Pair Tracer PTS 100/200 for only ÂŁ43.60 from Extera Direct
My experience with these type of cable tracers are, they work ok on data cabling as long as both end are open ie. they are not patched into a data switch/hub or computer at either end. If they are still connected the signal is either cancelled or degraded and untraceable at the other end. JMO.
What would you recommend for connected data cables?
I would go for the cable tester with someone at the far end with a radio. Having two people will take less than 1/2 the time as thre will be no walking back and forward. While it will take longer with the cable tester to start with it will speed up as there are fewer unknown cables to test
Reply to Data cable tracer? in the UK Electrical Forum area at ElectriciansForums.net
