DB In Bathroom | on ElectriciansForums
Discuss DB In Bathroom in the UK Electrical Forum area at ElectriciansForums.net
Stamford
Just after a bit of advice.
Please see my wonderful drawing attached. This 'Bathroom' is within an Officers Mess. As you can see from the drawing, each bath/shower is located within a room off of the main room/lobby of a room which has BATHROOM on the door. The proposed location of the DB is within the lobby. My take on it would be that as there are individual doors/rooms for the bath/showers then the db is not located in a room containing a bath or shower. It's nowhere near zone 0,1 or 2.
My concern is more around the environment. There is potential for this to be a humid area. I don't particularly like the location but just wondered what others thought. Would building a cupboard around it help or any other suggestions.
  • Room.docx
Put one in a zone 2 before.. niceic advice line were happy with it!
Assuming extractor fans are in use, can you place a vent to external/other space in the electrics enclosure, effectively giving it slight positive pressure?
Whether there’s a bath or shower in the room is really not here nor there….
The equipment installed has to be suitably IP rated for the environment… so if this is going to be like a changing room… where people are drying off and splashing drops of water around…. I’d be looking to see where else the DB could go outwith this room.
You could put it in an ip rated cabinet.
How many ways needed ?
There is also the ongoing problems if this is a gendered changing room....
For example, 2 or 3 burly male soldiers (you said it was an officers mess?) and you send your female apprentice in to reset a circuit breaker? Theyre not likely to shut down the entire functions of the building just to trace a small electrical fault sometime in the future.
Jokes aside... im just thinking of future circumstances about installing the DB in this particular location.
In domestic houses, particularly new builds, ive seen CU's in WC's.... which is fine according to regs... no bath or shower.
I've also seen older houses, particular farm cottages, where theyve changed a downstairs room into a utility, with WM, sink, dryer, chest freezer etc, then shoved a shower cubical in the corner....
Reply to DB In Bathroom in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
