db marking | Page 2 | on ElectriciansForums
Discuss db marking in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think I'm getting the jist......re label the DB circuit numbers to suit your methods.
I have seen some DBs marked in some odd ways, when we were panel building the project manager at one place wanted circuit 1 closest to the main switch,on the left, and circuit 2 on the right and so on, so you had all the odd numbers on the left and even on the right, ascending up over, but I have seen plenty of other ways of numbering
Conventionally the circuits are numbered from the incoming supply, usually from highest rated OCPD to the lowest, I think this was for historical reasons as now most internal DB bus-bars are fully rated so it don't really matter, maybe our teachers were from an older generation and the practice just followed on ?
Anyway, it doesn't really matter whatever the physical layout is as far as the schedule of test results is concerned so long as the data matches the correct circuit.
Reply to db marking in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
