Dead Short after IR testing | Page 2 | on ElectriciansForums
Discuss Dead Short after IR testing in the UK Electrical Forum area at ElectriciansForums.net
Spazz
Just had a call off my electrician (one doing council work)
He did a CU change - on testing he IR tested the lighting circuit (500v DC) and got acceptable readings.
When he energized the circuit - RCD trips. Found a dead short between N and E. Investigating now to locate which run of cable/accessory is providing this dead short now. There are no Low Voltage equipment on lighting so nothing could of been damaged.
Any ideas what could of caused this?
Reply to Dead Short after IR testing in the UK Electrical Forum area at ElectriciansForums.net
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
