decent wired alarm | Page 2 | on ElectriciansForums
Discuss decent wired alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Your choice is dependent on what size system you need and whether you need the functions of the premier panels for the small domestic systems I use the Veritas Excel and had no problems
Its 4 bedroom detatched house having 1 pir on landing 4 downstairs and 3 door contacts.
A customer of mine previous had a texecom that had the function to text your mobile when alarms activated. I want simialar system.
A Veritas Excel will give you 8 zones so with what you have planned all the zones would be used if it is likely that more protection is needed then a Premier panel would be your best option
Either option could be connected to a Texecom speech and text dialler to give you the text function
The Premier has facility for plug on com2400, this will send text messages including zone number, text, area, and device activated.
Reply to decent wired alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
