View the thread, titled "declared net capacity" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
Not as far as I can see. I have my own Eon form in front of me and it asks for TIC and DNC but not kWp of panels installed.
What page/whereabouts does it require it?
So it should be possible for the local installer to approach their existing customers with PV arrays (which are limited in output by the inverter) in the new year when he's got no new installs lined up and sell them an "upgrade" by adding a couple of modules at a now lower price than they would have paid at the install date a year ago and get some extra work from that as well as some happy customers which can benefit from the extra revenue this creates for them, am I right?
Would plug a gap until the new FIT's are widely accepted!
Have just looked at paperwork from my installers - they give Tic as 2.4 )from 10x 240 sanyos) so I guess that's where I got the idea that the power company would know the total rating of your panels if you actually put more than 4.0 kWp
so.............
the other day I installed a 4kw system. 8 panels on an east roof, 8 on the west to an aurora power one 3.6.
being east and west facing this ystem output will be less than a south facing 4kwp system. could I therefore, for the sake of argument, have installed a 4.5kW system with a 3.6 inverter and still got 43.3p fiTS as the actual output will be less than 4kW
I suppose yes,
that's at least what I've done in a roundabout way with the feed in restriction I had.
It's only the question whether you can add extra panels afterwards.
I personally would stick some more on the roof when a good deal comes along, but the opinions do seem to differ!
Regards
germ
East/West is a particular case where you can have a lot of panels on a twin mppt inverter. From memory on a PVI-3.6-OUTD each mppt can handle 3kWp of panels. I did an installation earlier in the year where with over 5kWp of panels on an east/west/south roof, with a bit of 3d trigonometry I was able to prove to the DNO it was less than 16A on single phase.
Regards
Bruce
Could someone confirm on what paperwork is the key figure of what you have installed and is used for FITs. My MCS Certificate has a DNC of exactly my panel capacity, but the estimated annual generation on the same certificate is not in line with SAP calculation (I have some shading) it is hight. Also for some reason my e-on letter has another figure that is a higher capacity.
Suppose what I am asking is that I would like to add some more panels but as I have some shading so adding 10% more capacity will not exceed the perfect installation, can I do that.
Gary
I know what your getting but the fact is the MCS certificate and corresponding paperwork of the installer (inc in your handover pack) has the panel information including kwp and number with serial numbers plus the inverter with serial numbers. If you add to this it's classed as a new/ additional instalation. You might not be meeting your DNC but that's bad luck!
The fact is their is noting stopping you doing this and I guess the big six will start inspecting installations to ensure this doesn't happen ! It's a grey area but morally you know it's fraud !
Reply to the thread, titled "declared net capacity" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
