Defender LED Festoon | on ElectriciansForums
Discuss Defender LED Festoon in the Electrical Tools and Products area at ElectriciansForums.net
K
keith915
Anybody used them? Are they as bright and/or give as good a spread of light as the standard 100w GLS festoon's?
Defender
From what I can see, they look the PCB of an average cheap GU10 LED lamp which I often use in garden lighting. These are low output effect lighting for shrubs and water features etc. I cannot see these as any good for site use. For now I would stick to a more tried and tested light source, I have yet to see a 110V AC wide beam LED ES lamp....anyone off to China?
A temp company I worked foor used similar stuff led on a roll like rope lighting on a big site in Edinburgh i we used it for stair ways and exit routes connected straight into mcb rather than a plug for chippies to unplug and overload It gave out a good background light specialy on the stair well but IMO its not realy much use in open areas or high risk, places that require good lighting
Reply to Defender LED Festoon in the Electrical Tools and Products area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
