G
geffg
hi, done my 2391 years ago and not done much testing since. On the forms it asks for details of Main switch; which switch does this mean ie- the one between the cut out and db or the one actually on the db? also when its a split board with switch and rcd; the rcd results for the protected circuits, is it ok to put the same results against each circuit.
sorry if being thick just might be starting some testing soon!
do you know of any links where i can get filled in examples?
