details of main switch on PIR | Page 2 | on ElectriciansForums
Discuss details of main switch on PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
"which switch does this mean"
the isolator is the property of the supplier, so you test from the DB.
regards, dno.
regards, dno.
The OP's not asking where to test from, but which isolator should they record the details for under characteristics of supply.
Incidently, isolators are not neccessarily the property of the supplier.
Reply to details of main switch on PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
