Difference in kw | on ElectriciansForums
Discuss Difference in kw in the UK Electrical Forum area at ElectriciansForums.net
L
lokesh.dee
Hi
we have a 50 h p motor driving a agittaor thru gear box 50 hp 1500:155 rpm ration rpm.
Frequency drive is dranfoss we are monitoring the power drwan by the motor is very less at 100% load.
The readings are as below at 100%
v 390 v
kw 19
amps 34
rpm 1470
motor name plate details
v 380 v
hp 50
amps 59
rpm 1460
Is the drive set up correctly?
How does the drive monitor speed? (Open/closed loop). This may account for
Can you take a pic of the motor plate and post...
As above the readings you list sound like the readings off the drive while running so 19KW reflects the power usage while running and not what the motor is capable of at full load. What is the KW rating of the drive written on the rating label somewhere about the drive?
Thank you sparks
if motor speed is 100% does not it mean 100% load. Then how can we measure the load???!!as i told the mechanical load is agitation for fermentation process if quantity or sp gravity increases load will increse??
[ElectriciansForums.net] Difference in kw
hai please find the deatils
Reply to Difference in kw in the UK Electrical Forum area at ElectriciansForums.net
