Different test results after DB change | Page 2 | on ElectriciansForums
Discuss Different test results after DB change in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
Is it common to get different test results when upgrading a db? Basically I done an EICR in November and came back to upgrade the db and done live tests on all the circuits, but my results were quite different. Like 0.30 ohms out on one circuit
A lot can depend on the environment the MFT was kept / transported to site in prior to the testing being carried out and if it was given time to acclimatise to the conditions of the premises being tested
This is one of the reasons why I'm not a fan of wholesalers on the day calibration events as it is difficult to produce accurate calibration results without the lab conditions to give a baseline to qualify the results to the required standard
Reply to Different test results after DB change in the UK Electrical Forum area at ElectriciansForums.net
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
