uksparks
Hi,
I have been doing some work in a kitchen this week, and to be honest its horrible.
All the walls are sodding brick and the plaster is all falling off.
Anyway, trying to knock into the brick with a an SDS and comb chissel, the brick got more and more loose.... It didn't help that I started cutting out too high and needed to go lower and make the area bigger anyway.
I knew the wall was only one brick thick so thinking it was not good...
Anyway, I pulled the brick and and you could see the plaster on the back... in the lounge.
I put the brick back in after trimming the rest on the floor and plastered it all back in.
Thank god the bonding / plaster was so thick! I can't say as I wanted to redecorate the lounge.
