Digital heat Controller wiring help required please anyone | on ElectriciansForums
Discuss Digital heat Controller wiring help required please anyone in the UK Electrical Forum area at ElectriciansForums.net
T
tojo$mojo
Morning Forum,
i am looking for some help reference the correct wiring for my thermostat i am making a home made incubator. I am a little confused on which way round the cables should go. By the way its 220v.
i will attach the a photo of the thermostat if that helps.
Any help would be brilliant. [ElectriciansForums.net] Digital heat Controller wiring help required please anyone
Ok bearing in mind that advice is just advice,I would say live and neutral in go to terminals 3 and 4 temperature monitoring probe to 7 and 8 and switched live to heater goes across 1 and 2 cant read the language though so not sure what max load would be across 1 and 2.Do you not have manual?
L and N in on 3 & 4 . sensor on 7 & 8. then 1 & 2 switch. L to 1 and switched L to heater on 2. N direct to heater. do not wire N to terminal 2 or it will go bang.
hi
i have just made a drawing as to what i think it should be like, from your kind explanation, i think its still wrong please be kind and sorry in advance for trying anyones patience.
Reply to Digital heat Controller wiring help required please anyone in the UK Electrical Forum area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
