Hi
I have three rooms. Two rooms have two lighting points, each with 3 GU10's coming out and 1 room and one point with 3 GU10's.
So I have 5 of these:
Neo Chrome Effect 3 Lamp Round Spotlight Plate | Departments | DIY at B&Q - http://www.diy.com/departments/neo-chrome-effect-3-lamp-round-spotlight-plate/178821_BQ.prd
I replaced my standard GU10 with these dimable LED bulbs (Philips):
https://www.amazon.co.uk/dp/B01KHIM7DC/ref=cm_sw_r_cp_apap_P4MUZkddPBdH7
Unfortunately when the dimmer switch is off one of the LED bulbs lights up dimly in each room, which isn't very desirable!
Here is the dimmer switch:
Crabtree 1-Gang 400W Touch Dimmer Pol Chrome Flt Plate - https://www.screwfix.com/p/crabtree-1-gang-400w-touch-dimmer-pol-chrome-flt-plate/35917
Suggestions please!
Perhaps I should take one GU10 out in each room and put in one standard bulb?
If I have to replace the dimmer switch could anybody recommend a suitable swapout, preferably polished chrome.
Many thanks I appreciate this!
Suggestions please!
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
