Dimmable flood light | on ElectriciansForums
Discuss Dimmable flood light in the Electrical Tools and Products area at ElectriciansForums.net
LONDON (barnet)
Afternoon all, looking if anyone can point me in the right direction.
I'm looking for a dimmmable 10w flood light (integrated)
Well aware I could use older style with dimmable lamp but looking for something that looks a little better.
Cheers
The whole point of a flood light is that it is supposed to FLOOD LIGHT and so would defeat the object. Other option is to get an IP rated GU10 and put a dimmable LED in it. We had the same request from a customer - told them the same.
Any "Raw" LED is intrinsically dimmable. - By which I mean current-source driven lamps without inbuilt mains SMPS power supply. Those lamps will commonly using 700mA drivers, sometimes 350 mA. These lamps are just LED's, - arranged sometimes a few in series, or perhaps (rarely I think due to die current sharing problems) in mixed series/parallel combinations. 700mA dimmable LED drivers are also available for mains dimmers or for DMX or 1-10V if that's your thing
Check out for one random example PolyFlood 12 LED Flood/Spotlight | Led-Zip Lighting | LED Lighting and LED Light Consultancy UK - http://led-zip.co.uk/polyflood/polyflood-12/, there will be others - Collingwood say. And then find some suitable drivers. May be worth just checking with the manufacturers, but I can't see it's likely to be a problem.
Don't expect it to work out cheap though, the mass market won't be working for you.
Reply to Dimmable flood light in the Electrical Tools and Products area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
Hi, I'm installing a smart lighting system for ambient lighting in a "traditional" kitchen dinning room it's a big area. I want to be able to put...
