Dimmable halogen bulbs | on ElectriciansForums
Discuss Dimmable halogen bulbs in the Lighting Forum area at ElectriciansForums.net
Skippyroo
Se20 8tg
The bulbs in my daughter's house keep blowing they are gu10 dimmable 35 watt should she get a lower wattage bulbs
halogen are known for blowing. also wasteful. time to convert to LED. simple bulb change, although the dimmers ,if fitted, may not be suitable for LEDs.
It's not only the quality of the lamps that's the problem, it's the quantity.
If you have a single lamp in the centre of a room, as we used to, then, if it has a rated life of 2000 hrs, then you would expect to replace it after 2000 hrs of it being lit.
If you have ten downlights in a room, each with a rated life of 2000 hrs, then you can expect to replace a lamp every 200 hrs on average.
convert to LED 10 x the lifespan and 1/10 x the leccycost. isn't metric wonderful. a system designed for apes to be expert mathematicians.
Reply to Dimmable halogen bulbs in the Lighting Forum area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
What voltage are the lamps could be a faulty / failing transformer
