Now, over the years, I've fitted loads of LED downlights - 100s if not 1000s by now - just like you guys/gals probably. They always work, but this week they don't:
Four 5W dimmable LED downlights. Varilight 100W dimmer - minimum load either 0W or 10W depending which spec you read. This dimmer goes through an auto-setting either when it's first switched on or evoked by pressing the on/off switch several times. It defaults to trailing edge.
It goes through the setting procedure but not always.
On this occasion the lights don't dim at all....even harsh language doesn't work.
They remain at maximum brightness.
Changed the dimmer - no difference.
Could it be that there's not enough load? I've fitted small numbers of LED d/l s before without issues.
Could it be that the cpc connection has a break between switch and one or more lights? I didn't think LED dimmers needed such an 'earth' reference to work - but happy to be corrected.
Just got some more dimmable LEDs to try not hopeful...
I have had problems with Varilight dimmers buzzing but they've always worked in the past.
What do you think?
What do you think?
