View the thread, titled "Dimmable lighting problem" which is posted in Commercial Electrical Advice on Electricians Forums.
Stick an 'optimistic' tag on this someone....
There is a chance that there is a permanent live at the lights. Maybe not visible, but in a joint box above the ceiling. Move the mirror feed onto the perm live, from the switched live.
Downlights? pendant? You're going to have to do a little detective work. It could be a fairly simple solution.
Sorry but without being there and investigating it is hard to give a certain answer. does the mirror have switches or sensor switches on it? so that if a permanent supply is put to it it can be switched by those.
Reply to the thread, titled "Dimmable lighting problem" which is posted in Commercial Electrical Advice on Electricians Forums.
