N
NeilF
We had 6 Aurota (GU10 fitting) LED downlights fitted.
With the first dimmer switch:-
So the dimmer was changed. Now:-
So the latest dimmer is great, except you cannot turn the lights down far enough.
Can anyone comment on this who has experience with LED lights & dimmer switches? Is there a reason for this odd behaviour?
- If you turned them on (pressed the button in) with a lower setting the lights would not come on, until you then rotated the dimmer to a higher setting, when they would then spring to life at a fairly bright level.
- When the lights were on, you could turn the dimmer down to a very lower brightess. If you turn them off & on (pressed the knob twice) the lights would be off (as mentioned previously), until you turned them up enough to spring into life.
- The lights (all six) would buzz sometimes.
- On the lowest dimmer setting (knob rotated all the way anti-clockwise), the lights are still fairly bright. Certainly not as dim as we'd ideally like.
- No buzzing now! Good!
